Originally Posted by carbon coupe
(Post 14681613)
I did this. Tired of fishing for a cord or having it hanging out and getting covered in ice.
Well done CC, reps sent your way
Love the cord mod CC!
I kind of wish I would have thought about doing something with the plug on my X when I had the bumper off and cut up. Even though I have never plugged in my X it would still be nice to have a nice looking plug outlet. |
Originally Posted by GIGGER
(Post 14681891)
CC, reps sent nice clean mod!
1 Attachment(s)
Would you guys go with an oem replacement or an all Aluminum radiator (2002 Ford excursion All Aluminum Radiator 7.3L 8 445 | All Aluminum Radiator | Ford Parts
Note: I can get oem parts just above cost Here is the crack Attachment 227644 |
two ways to look at it, all aluminum will never have any issue like that (may possibly have another though later in life) OR it took that long for the OEM one to have this issue it will last you a good while...personally i'd go all aluminum and try to eliminate the problem area.
I'm going to be parking the Ex off to the side of the driveway and plugging in the trickle charger since i'm leaving for Vegas tonight!! |
Originally Posted by AlaskanEx
(Post 14682323)
I'm going to be parking the Ex off to the side of the driveway and plugging in the trickle charger since i'm leaving for Vegas tonight!! Thats how I looked at it although the oe lasted 215,000 miles. I think it will make my choice easier tomorrow when my buddy gets the price on the oem unit |
I got my OE radiator on ebay for $125 with free shipping and it is very good quality! I couldnt justify an all aluminum versions costs considering mine went 320000 miles and it just had a small leak that had sealed itself, i only replaced it because i had to remove it to get the engine out for timing cover replacement.
Originally Posted by Mach1394
(Post 14682342)
Well for $150 if mine ever fails my 5.4 will get one of those aluminum ones ;) Can't beat that price!
Originally Posted by USCG_PA
(Post 14681640)
Nicely done! Reps sent! :-jammin
While I did not do anything as nice as your project, I did give the Ex and my wife's Edge a bath today. :D
Originally Posted by Skip1970
(Post 14681732)
where you get that nice block plug things at?
Originally Posted by Pitcrw6
(Post 14681817)
Where did you get that at? What did it mount to? Info info info
(Post 14681891)
Originally Posted by Snowseeker
(Post 14682050)
Originally Posted by LivingLarge
(Post 14682197)
Its a "NOCO Genius GCP1 Black 13 Amp 125V AC Port Plug" I found on ebay. I bought an extra fog lamp bracket, made a mounting plate for the outlet and mounted the bracket just inboard of the LH lamp. Drilling the holes in the top flange of the bumper was a serious pain, had to cut down a drill bit to fit up in there. On the bottom flange, there were already holes for the air deflector so I made a bridging bracket, used a large fir-tree trim fastener for the fog bkt to the bridging bkt, then bolted the bridging bkt to the bumper flange. Looking back, I should have pulled the bumper off to drill the holes and made the job easy....but the moron in my head took over my one engineering brain cell and had at it. After that I cleaned truck plug contacts, applied dielectric grease and sealed the plugs together with a sticky vinyl wrap. I have yet to test. Tomorrow evening maybe. Im hoping the 13A is enough. |
(Post 14682563)
Thanks guys!
Its a "NOCO Genius GCP1 Black 13 Amp 125V AC Port Plug" I found on ebay. After that I cleaned truck plug contacts, applied dielectric grease and sealed the plugs together with a sticky vinyl wrap. I have yet to test. Tomorrow evening maybe. Im hoping the 13A is enough. }> |
(Post 14681817)
Stewart |
(Post 14682267)
Note: I can get oem parts just above cost |
