$10-20
Get the kit that has the install tool and comes with Loctite. Many companies make these, perhaps the best known is Speedi Sleeve. (SKF) Also; Timken FelPro Pioneer Parker etc... |
With the oil slinger bit, my 351W didn't have one either. I used a Cloyes double roller timing set, and the gears are thicker than the single roller sets.
Matthew,
Is it keeping your balancer from seating all the way? I have a True Street double roller in my truck as well, but don't have any issue. |
Originally Posted by ArdWrknTrk
(Post 14099627)
Matthew,
.... but the seal is in the same place as before. ???
(Post 14099636)
Originally Posted by FordFETruck
(Post 14099644)
Yep, same groove, pulleys line up perfectly.
(Post 14099644)
If it is, I doubt there is any difference in timing gears. |
Originally Posted by Piston Honda
(Post 14099665)
Are you saying your balancer had a groove also?
(Post 14099665)
That's why they make a repair sleeve. |
(Post 14099668)
I meant that Piston Honda says HIS balancer is in the same place.
I called Edelbrock this morning for the hell of it and the tech told me the gear is the same thickness as the stock one. So that's the end of that.
I went to NAPA to see if they had a Speedi Sleeve but they didn't have one. I went on the SKF site but it's down for maintenance. Received some parts today the list includes Performance Distributors Duraspark II dizzy, module and Inferno coil Painless Duraspark II harness Flowtech headers 3G harness, 175 megafuse and harness Trans Dapt alternator pulley http://i1318.photobucket.com/albums/...ps5cad300b.jpg http://i1318.photobucket.com/albums/...psfd23c468.jpg http://i1318.photobucket.com/albums/...ps5572e3c8.jpg http://i1318.photobucket.com/albums/...ps4b942a08.jpg I'm not even going to post a pic of the pulley, it's very poor quality and I'm sending it back. Does anyone know of a good pulley for a 3G upgrade? I looked in the "how to's" on the 3G install and it shows him switching pulleys, but he doesn't specify where he got his single groove pulley. |
Cool stuff. But it is a shame about the pulley. RJM used to have them cheaply, but that place appears to be gone.
Here's the new headers
http://i1318.photobucket.com/albums/...psdf540386.jpg http://i1318.photobucket.com/albums/...ps6ea678d7.jpg The only issue is the driver side is very close to brake lines. http://i1318.photobucket.com/albums/...ps9ea4ee52.jpg http://i1318.photobucket.com/albums/...ps758ceb12.jpg http://i1318.photobucket.com/albums/...ps67c6059a.jpg http://i1318.photobucket.com/albums/...psb8b46cd7.jpg http://i1318.photobucket.com/albums/...ps9978ca76.jpg Overall a much better fit. |
Looks good. A bit of bending and the brake line will be fine.
