Yep, it's funny. They slow down and then they see it's a decommissioned vehicle or one from another jurisdiction and then they speed up.
I'll be painting it in the spring; I'm thinking triple black.. |
Today i replaced he cat converter on my truck .its still as slow as a tortoise.
1,000 pages!!!
Yay! Tim, put some nonsense stickers on it and leave it black and white. }> Do you get to keep all the goodies? :D |
Originally Posted by VOTR 1962
(Post 14802327)
Tell us more about your truck. |
Tim,
Leave the drain plug loose on the Pathetica. :-X22 |
I like the K9 cage! }>
I may put one of those in the Bronco. :D |
Originally Posted by bruno2
(Post 14803477)
If you see the cost of such a cage, you may think twice.. It's about as much as I paid for the vehicle.
The only 'goodies' I got to keep was the cage. I had to get a salvage center console (will paint it) as well as the overhead console. I also have the famous '02 Explorer Rear Plastic Crack' but have a replacement panel on order. The rear end has a little whine, but I'm hoping a fluid change will take care of it.. |
Originally Posted by KsCop
(Post 14802291)
I'll be painting it in the spring; I'm thinking triple black.. ION: I got the new ARP head bolts installed, along with Fel-Pro head gaskets and Mr Gasket header gaskets. I opted for the upgraded header gaskets. I need to resupply all my fluids. Once that's done, I'll re-crank it and verify my repair. BTW: I do not recommend re-using head bolts on an untouched engine again. Most of our engines (and older) are at that point where metal fatigue is going to set in. Keep Wrenching. |
Originally Posted by ArdWrknTrk
(Post 14802349)
1,000 pages!!!
I dropped the mid tank because the hose was horribly kinked and I couldn't reach the clamps. I have a filler neck from an 87 that I understand will allow me to trickle fuel in even faster. Tomorrow that is going to be installed. Is a giant amount of cork between the tank and the underside of the bed normal?
I'm also working on the tailgate latch. A previous owner neglected to drop the gate when he pulled out from under his 5th wheel. Nothing about the latch worked properly. I was trying to jury rig something, got a little carried away with the welder, and burnt a rod in half. I got lucky at the yard and picked up an entire assembly. It's just waiting to be cleaned and installed. P.S. I changed the belts too. |
Cork? I've never seen cork between the tank and the bed on these.
(Post 14804841)
Cork? Never seen that....
Originally Posted by ctubutis
(Post 14804884)
A previous owner of this truck did some very strange things. I was planning on taking pictures of the truck tomorrow and telling what I know about it in the introduction thread. |
