- 89 302 EFI acts like carb flooding
- dumb question
- Where does the vent hook to?
- What is the problem?
- feul going from back tank to side tank
- bronco fuel tank in pickup.
- 302 AM Fuel injection?
- fuel injector rebuilding
- fuel hose life
- resistor to cancel AM1 & AM2 codes?
- how do i hook up electric fast idle?
- Fuel Pressure Issue
- 351M Stumbles at WOT
- Code 512, here is what fixed mine
- Inertia switch ?
- Discontinued parts suppliers needed%$#@!
- how to adjust carter afb?
- Aluminum Intake needs fixed
- Mechanical or Vacuum Secondary
- bad gas mileage, injectors or regulator?
- Carb Recomendations?
- Changes to my Holley 4180
- Stp fuel injector cleaner
- changing a fuel pressure regulator
- Carb Identification
- Carb Question: Need vents? Charcoal canisters?
- Backfiring 460
- the easiest way to clean rust out of fuel tank
- converting to fuel injection
- Acetone Fuel Additive
