- Carb question for 400
- How to Check For Bad Fuel Pressure Regulator
- Carter YF parts
- Too lean when cold
- Butterfly is Sticking...Why??
- Code 33 - EGR valve
- Not sure if the Carb is it
- Use Diesel water trap to strain gasoline?
- Ford Racing MAF Conversion Kit
- OEM Fuel pump - F150?
- Vacuum Port?
- Fuel Injectors Only On 1 Side?
- Another gas smell problem
- it won't idle
- Question on Holley 2300 500cfm
- '85 F150 EFI, fuel pressure?
- The Hidden Identity
- tuning a carter afb for e85
- Starting Problems
- truck avenger power valve
- Starting problems w/ 1986 302 w/ efi
- adding fuel filter on a 64 f-100
- Fuel System Gummed up.... what to do?
- 1985 bronco 351 fuel pump shooting out fuel!?!?!
- TPS setting, etc help needed!
- Front Tank Overflows?
- LxMan1
- fuel pump cost - getting burned?
- Identifying a performer carb
- Be Prepared
