- here's one for ya
- Reman Carb or New Carb
- Can't Locate Fuel Pump
- EFI to CARB conversion
- no gas out of jets
- manual vs. electric choke
- fuel problem
- Carb hesitation
- Who's got a Carter Carb!!
- Fuel injector mod?
- Heated fuel burns better
- holley 600cfm stutter
- Starting Problem
- Flow ratio on fuel injectors
- LPGas
- the p_i_t_a carter yf
- EFI Throttle and Choke Cables
- New Fuel Tank
- Larger Tank
- fuel saver
- Quick Question
- Fuel pump q's
- How to setup choke
- Crazy high idle
- 88 5.0 EFI running rich Need Help - Desperate!
- help with carb
- pintle caps
- Motorcraft 4bbl rebuild advise sought
- carb question
- 4180c 4brl holley adjustment
