- oil change after storage
- Jiffy Lube
- Pros & cons of mixing syn & dino ATF
- Gibbs penetrant
- What oil should I use?
- Do not use Quaker State oil
- Which of these oils would you use?
- oil "break in" period
- Transmission Fluid Advice Needed
- Engine oil question
- Transfer case oil
- using "diesel" oils in a gas engine
- what does the HD in HD30 mean?
- Fram Oil Filters @ Pep Boys, 2 for $7.
- Pre luber?
- need help quick!!!
- Found diesel rated 10W30
- Napa 15-40 Synthetic
- best way to open up an oil filter
- Synthetic Oil vs Standard Oil
- Diesel Rated 15w40 or 10w30 in a gasser
- Kroil/aero-kroil and Kreen
- magnetic drain oil plug - cause for alarm?
- looking for more input?
- Purolator oil filters for $1.99
- Flat tappet cams
- new motorcraft 15w40 cj-4
- any snake-oil for lifter noise that worked
- News Flash - Why 75,000mi Is So Huge
- oil additives, such as Auto-rx
