- Gear not shifting down when cold
- ? pinion bearing ?
- No first gear?
- E4OD won't stay in OD
- 302 four-speed, want closer ratios
- B&M Electronic Shift Improver
- overdrive
- dana 44 options
- C6 cast iron extension housing gasket...?
- Trans knocking
- 429/C6 conversion to AOD
- 8.8" questions
- 4.2 tranny possiblities
- e40d clutch pack exploded
- Slips in second gear ????
- Trac-lok conversion question
- E4OD - no 3rd or OD
- Add holding power to your Trac Lok?
- is this a D70 limited slip?
- Lets talk about swaping a manual in place of an E4OD ATTN:HAVACK
- 8" rear end
- strange sound from rear end
- 97 Trac-Lok for 10.25
- M50d
- What Kind Of Transfer Case Do I Have?
- question about rear end and gears.
- Gear Swap ?
- Shifting Irregularities
- np208 PLEASE HELP!
- 4 x 4 transfer case
