- C6 broken shift arm -- was trying to make DynoMax header clearence
- Doug Hamby of Dougs Transmissions
- My front Differential leaks on my '98 Ford Explorer
- LS or not and Seal Mod
- C6 lockup converter?
- trannies
- Clark overdrive?
- M50D problem
- Tranny seems to be shifting hard
- T-18 rebuild reverse idler question
- What rear axle do I have?
- First differ
- e40d torque conv plug install
- Need help PLEASE on an A4LD.
- Interchangable drive shaft?
- What tranny has the widest range of gearing for a diesel F250/350?
- What is the easiest way to change a front seal on an e40d
- tranny interchange
- Do Ranger t-cases have clutches in them?
- C6 tranny fluid replacement
- 3 spd tranny problem
- rear seal e4od
- Removing Fill Plug
- Diff kits
- T56 to 302 in a '79 F150
- 92 F150 5speed probblems
- 1979 4x4 F-150 front u jonts in the front end
- Dumping the ZF 5 Speed, want something stronger
- shudders when downshifting
- Chain Driven Dana 205
