- Mlp On E40d
- Puzzling E4od
- cleveland and tranny stupidity
- 78 f150 front and rear diff $$$$
- Trans swap info
- how do i unlock a detroit locker?
- ShiftKit question!
- 1978 F150 Synchromesh
- unusual gears?
- No Forward Gears ~ Help!!!!
- 4x4 lock out hub problems
- 10.25 rear discs
- C6 vs C4
- What kind of Tranny do I have?
- C6 compared to AOD
- Driveshaft / Pinion angle Question.
- help with clutch pressure question
- E4OD gear ratios
- Uh Oh. C-6 Install problem.
- Clutch Master (Non)Interchange
- 9" axle decode help please
- Diff Gear Compadability
- Breaking in Ring & Pinion
- c4 tranny leaking from speedo cable
- transmission failing its mission
- C-6 shift improvement
- E4OD w/E Brake bolt pattern???
- Anyone ever rebuild a C6?
- Major oil leak from E4OD
- E4OD Problems
