- transmission ID.
- C6 Hard 2-3 Shift ???
- 90 E4OD No Forward
- hard 4wd engagement
- Tranny Woes
- slipping, before i order a kit...
- Simple answer I am sure..........
- What transfer case do i have?
- Clutch fitting...
- gear vendors wiring diagram
- Rear axle question
- C6 issues
- TCI valve body for AOD
- Clutch will not release
- 86 c6 diesel forward planet ring and hub qustion
- is a free np435 worth it
- E4OD shift feel
- C-6 case shift lever orientation?
- Need Trans. for 02 F250 7.3l
- axle swap considerations
- Have Dana 60 front went down in value???
- C5aw-? 9"
- C6 Questions and Issues.....
- 9 inch rear end strength?
- Does axle gear ratio swap require computer calibration on E40D?
- gear vendors 2wd to 4x4
- 79 f150 transmission swap
- C6 servo's and levers
- Growling ZF5...
- homemade short throw shifter
