- 1990 E4OD problems have engine codes
- Loose Manual hub question
- 93 E40D Trouble
- Putting 2.9L A4LD behind 4.0L bad idea?
- zf5 grind, kind of a weird grind tho
- Anyone familiar with a Powertrax locker?
- Dana 61 out of 1979 E-250 for sale.
- Where to find specialty tools for e40d rebuild
- 1993 e4od erratic operation
- Anyone heard of this A4LD problem.. strange
- clutch help needed
- f150 4x4 4r70w rear leak?
- C6 conversion to an overdrive transmission
- 1991 Ranger clutch master cylinder or slave cylinder?
- AOD issues
- ZF-5 Grinding when shifting into reverse
- is this a newer 1997 8.8 axle - code is wierd
- Servicing front and rear end
- put a newer rear end in my 97 f-150 speed difference?
- 3 speed stuck in 2d
- 2003 E350 4x4 Van Conversion
- ABS Brake locks automatic tranny shifter
- 93 E40D into 95???
- slipping clutch 2nd opinion
- what rear axle do i have?
- do I have a torqshift tranny?
- 2009 ford f250 superduty zf 6speed issue
- Automatic to Manual transmission swap
- C4 shifting problems
- E4OD manual valve body?
