- Torque spec Dana 80
- Dana 70 axle length?
- 97 E40D
- transfercase on a f 350
- e4od goes forward in all gears
- torque converter
- e4od pump
- Strange c6 problem
- e4od help needed
- Trans swap, then won't start?
- T-18
- 1988 F-150 5.0L with a C-6 into a ford ranger
- Big Block Tranny Question
- ZF5 Tranny fluid
- trans wires
- 1996 F250 E40D - No Gears
- Trans swap out AOD for E4OD
- Transfer case woes
- what is this part called
- e40d slips when shifting.
- AOD question
- '97 4R70W strength
- Shift point seems low on C6, what should it be?
- trans only has drive
- code 452 and flashing o/d light?
- E40d 7.3l 460
- e4od question
- dana 50 and dana 60 parts interchange.
- e4od pump bushing
- e4od pump
