- c6 failure shifting from 1st to 2nd man val bdy
- Xtra firm shifts and OD off light flashing
- e40d shifting hard in reverse
- Pinion gear slop
- Valve body assistance please...
- 8.8 Pattern Check (looking for input)
- Driveshaft Fit Question (99 f150)
- Speedometer Gear keeps falling out??
- What differential is this?
- Group Buy Trans Controller AOD-E, 4R70W, 4R75, E4OD, & 4R100
- bw 1345 vs 1356
- help!!! e4od downshifting to neutral
- T170F in a 78' F150
- dana 60 kingpin load rating?...8.3 cummins swap
- Time for 8.8 rebuild
- Is 240 to hot???!!!
- Blown transmission on vacation
- 4R70W Questions
- 1996 E4OD FAILED! What Now????
- c6 id help
- Transmission squeals when changing gears
- E4OD rough shift
- pulling junkyard trans A4LD 4.0 Explorer
- E4OD accumlator body
- 4x4 issue with a 98 Expy
- FE/FMX swap questions
- Transmission slipping!! HELP!!
- a4ld pushing the front seal out
- AOD- .080 or .061 Reverse Friction band?
- 99 D-60 disc brake
