- Haynes says 140w for T18, others... 80w-90?
- 2001 Excursion 7.3L Tranny Problem
- Replaced E4OD but now it's not working right. Help Please
- 5spd trans from bus to truck.
- 4R70W shuddering issue
- 4R70W question
- C6 Trans
- E40D REBUILD
- Torque Converter Nose Will Not Seat Into Crankshaft. Why?
- swapping factory LS from rear to front?
- AOD torque convertor 4x4 vs 2wd
- Easy rotor question.
- E4OD mystery: no TCC lockup, no OD light, no codes
- Tag Numbers on Rear?
- 10.5 axle
- 10.25 Trac Lock Clutch Replacement
- 2001 F-350 Shaking at 45-55 Not When In 2nd
- Manual transmission code ID problem - anyone?
- C6 swap in ?'s
- Installing T19 into 86' F250. HELP!!!
- New TCI C6 problems
- Dana 80 Spring Perches
- Pushes left
- Motor oil in C6 Tranny Pan
- 97 E4OD in place of a 86 C6
- 96 E40OD Diesel Torque Converter
- need gaer help!
- used magnetic sun gear in my 4r70 help!
- C6 adjustment 1st gear
- Need good tranny guys
