- A/C is swallowing orifice tubes.........
- I can only get 26mm hg on vac- is this enough?
- condensor installation- 87 f250 diesel
- 87 f250 dessicant? on 134a conversion
- Evaporator hose disconnect?
- help
- "99 F350 vacuum diagram
- cleaning out my R-12 system
- Odd? AC stops cooling after awhile. Frost on somthing out there!
- A/C problem vacuum leak, help finding please.
- Any experience installing under-dash evaporators?
- Blown 134a conversion-what now?
- ac cut out at 1800rpms
- a/c pressure looks ok but very little cool
- A/C CoP in relation to temperature
- AC with a mind of it's own
- Aftermarket Sight Glass for 1990 F250
- 1990 Determine status of a/c
- Going back to R-12
- Possible a MAX A/C problem
- 134A conversion problem
- a/c clutch questions..
- "defrostin" When 4-wheeling
- Clutch plate shim removal questions
- 2004 F250 6.0 : anyone have pressure numbers?
- HVAC blower motor
- 2003 Windstar air not as cold as it used to be.
- HVAC FAQs for 97-03 F-Series (including Navigator & Expedition)
- a/c seems to be freezing up
- A/C Not Working...can't find lower fill valve?
