- Is my alternator going?
- heater not working
- 1996 Ford Explorer leaking coolant
- Where to take old coolant?
- electric fans
- A/C compressor for onboard air
- Best guess why heater hoses are disconnected?
- 1997 Ford Ranger Temp. Gage Question
- Strange Temperature Reading
- temperture question and front drive line question
- how hot is too hot?
- 78 f250 a/c
- 01 X defroster problem
- 400 a/c
- Coolant Leak
- Antifreeze/Heat blower
- '96 Ranger 2.3L No heat/Defrost
- Strange Thermostat behavior
- j-valve location
- Overcooling problem
- where is the radiator drain valve (petcock?) located on 98 Expedition 4.6L
- A/C disconnect
- Heat / AC fan intermittent noise at idle
- A/C and climate control system
- Doesn't Blow Hot Air
- Steamy windows and mystery coolant
- '99 Exp. A/C blend door actuator. HELP!
- vent always open?
- freeze plugs? brass or steel??
- no power to blower
