- The a/c from my superduty will only blow from defroster
- ackits.com for '76 F250 noise
- temperature fluctuating
- Compressor Clutch??
- Radiator clog or?
- 80 f150 AC into 76 F150?
- defrost stuck, only comes out thru vents
- Electric or manual cooling fans for 4x4
- AC discharge
- Defroster runs when engine is off...HELP!
- 97 Explorer AC quit working
- blower switch
- new fan
- Miner leak in radiator and heater.
- Radiator Confusion
- Will old('76) evaporator hold pressure of 134A?
- early 80s AC to a '76 without AC?
- Installing new radiator--how to get block empty??
- coolant not reaching opperating temp.
- Cooling system problem that shouldn't be....
- Help! No heat! Winter around the corner...
- Lost radiator cap
- a/c controler wiring daigram
- Timing Chain Cover Coolant Leak
- Newbie with question
- thermostat
- cooling system pressure
- Need heater core foam?
- 98 Navigator,No Heat
- coolant flush question
