- No defrost, what gives?
- Hot A/C after crash
- e/fan question
- Blower help asap
- Truck just overheated, need help troubleshooting
- No Heat
- 92 F150:'Vent" position gives the most heat?
- Too Cold A/C?
- For those with a blend door issue.
- thermostat
- no heat in 92 f-150 after New radiator?
- No AC?
- 1992 F-350 blend door? Where is it.
- coolant temp. sensor
- 1992 F-350 Diesel with A/C
- How do the climate controls work?
- Heater Blower stops at highway speeds
- Ford Premium Anti-Freeze
- ac pump, air?
- Tempurature fluctuation problem
- radiator problems??
- Expolrer 98 no heating...
- 01 F150 No Heat
- Coolant Spewing
- A/C problems
- water running
- adding refrigerant to 99 Expy
- style of thermastat housing
- Block Coolant Drain Plug Installation
- blower motor?
