- A/C pressures
- Flushing coolant on1986 ford f150
- New radiator/lines.. Shoots fluid out when warm
- Arizona Mobile Air, anybody ever use them???
- 3 Row or 4 Row?
- A/C Evaporator Core 89 f-150
- AC will turn on when I move the switch to vent
- AC Compressor won't kick in - 93 F250 Diesel
- Radiator. Does size matter?
- a/c condenser line rotten and leaked
- Wacky temp guage!
- Radiator leaks. Radiator Cap problem?
- Erratic cooling 2004 F-250
- Compressor won't kick on ('79 F150)
- Best compressor for '73
- no voltage to compressor clutch
- leakkkkkkkk
- ford truck rad.
- A/C blows warm when driving...but...
- No Cycling on Compressor
- 98 Exp only cools w/Max AC
- Cooling System
- Need A/C blend door/vacuum line Diagram 1997F150
- not a truck but i need help
- Some R-134 adapters cause leaks
- ac and 4wd crosswired
- f150 bad compressor
- Electric Fan... Maybe?
- My 86 is heating up
- R12 to 134a
