- Alternative refrigerant less flammable than HCs
- Evaporator outlet size?
- Do you need to change the TXV Valve with 134a conversion?
- still overheating -- cleaning the radiator, perchance?
- A/C not Cooling at All!
- Barb fittings on 134a conversion?
- ac into non-ac truck
- E350 Cooling System???
- A/C transplant?
- AC doesn't cool after conversion
- '96 Explorer 4x4, A/C fan dies on accleration
- High Discharge Pressure
- AC - Low pressure port 2003 F150 SC
- Help! Need a/c idler pulley for 1980 F-150
- Running hot...why????
- overcharged AC
- a/c schrader valve guts
- Are parts stores A/C charging kits a bad idea?
- orifice tube removal tips...
- mid 70's AC seal needed---HELP!
- what all is involved in retrofitting a/c to a non a/c truck?
- burping system and water gushing
- Condenser not showing...
- A/C Spring Lock Coupling-Cannot get Apart-Help !
- A/C pressure test ?
- Plugged rad?
- twin throttle body
- Stock Oil Cooler Versus After Market
- Fan clutch or no fan clutch?
- A/C Recharge
