- 98 Explorer a/c pressure port location
- 2002 Expedition Rear AC
- 2005 Expedition Rear Air noise
- A/C and heat not working in rear vents
- A/C Outlet temps too high
- Voltage at compressor - no clutch engagement?
- Intermittent AC on a long trip.
- 1989 F150 A/C problems
- Help picking larger capacity radiator
- Squeeling when A/C is turned on high
- A/C - Replace just clutch or compressor also
- Vacum Port
- Leak in Vacuum controls for air distribution
- 99 Expedition - Where is the low pressure connector?
- A\C clutch replacement... how easy?
- servicing the a/c on a 2000 f-150..
- Belts and hoses
- Accumulator/Filter Drier
- Anybody try to use a digital climate control in their 70s pickup?
- Need help w/ 04 SD AC problem
- A/C Goes from cold to hot intermittently
- 1990 f150 a/c ??
- ac compressor
- AC blower went from vents to dash instantly?
- 2002 F-150 A/C problem
- 97 f150 ac vacuum lines
- 96 Explorer A/C Compressor
- no serviceable oriface for car
- coolant out of core overflow
- 1999 Ford Econoline
