- Heater Hoses
- r22 freon
- compressor problem?????
- a/c psi
- Cold in the back, hot in the front
- new 351M running hot
- AC problem
- Played around with new toy, infrared thermometer
- Charging Chart???
- Coolant leaking onto headers?
- fan shroud for 400m/460 swap?
- 2002 Explorer 4x4 Blend Door
- Radiator side's Swap....
- air conditioning
- AC Question
- Orifice Location? - 95 Explorer..
- 99 f-250 Compressor Connection
- OK, time to fix AC. '86 F150
- Small window A/C unit in a truck?
- 96 Crown Vic Intermittent Compressor
- hose for R-12 gauge set needed
- 1988 AC compressor coil problems?
- AC and Odometer crapped out
- AC Clutch Wobble
- 1992 Ford f150 ac problem
- a/c not always cold
- 90 f250 heater blower replacement
- 2003 ac unit removal for defrost venting
- Fan clutch not working?
- 1977 F-100 AC capacity
