- changing out compressor
- heater core probs...
- Its hot!!
- Trans cooler by right rear tire
- Secondary A/C system
- engine temps?
- All of a sudden!! Mildew smell.
- Converting from R12 to R134
- 2003 F150 SuperCrew A/C Problem
- Amount of Room in Tank/Reservoir (?) ...
- bad compressor? 2004 F-550 powerstroke
- Blower only works on high
- 302 overheat at idle
- 351 overheating when air is on
- Basic A/C question
- 2006 F150 a/c problems
- A.C. Issues
- 02 f250 a/c clutch switchin on an off
- a/c recirculating switch needs to be switched on every time engine is started
- Going on 6 years and still overheating!!
- R12 Compressor upgrade!
- 2001 ford escort ac prob.
- 05 250 No lighitng on climate control
- fan trouble
- A/C Compressor keeps leaking oil
- a/c seems to freeze up
- A/C Install
- A/C clutch or something else?
- Vaccum or air Leak in the ac/vent/dash pot control
- EATC/Vacuum issue
