- MASSIVE over cooling
- Blower Motor door...vacuum-related help needed
- '96 Explorer A/C Smoke Under Dash
- purging system
- PAG Oil viscosity question?
- 2.3 A/C Bipass Possible
- 88 Bronco Over Heats
- Coolant leak
- High pressure switch
- vacuum pump
- '99 F350 A/C blows warm
- 03 Expedition 5.4, where does A/C drain water out of?
- 97 Expedition AC orifice tube location??
- White vacuum line fixed
- High pressure service port leaking
- 1996 Explorer A/C problem
- 1993 Exployer Runnung Hot
- 1998 F-150 A/C Problem
- How to replace A/C vents? 94 F150.
- old a/c
- 94 Explorer cold air on my feet
- blown top tank..
- Radiator trouble...
- Max AC problem
- '99 Ranger - A/C quits cooling at 60+ mph.
- A/C Blower problem
- A/C air switches from vents to floor
- AC Compressor cycling on/off
- Better comp than York for '73
- 99 f150 blower resistor location
