- 4.0 weight?
- 2005 4.0 sohc 4wd swap for a 2001 4.0l sohc 4wd
- 4.0 Sohc-01 Explorer Sport
- alternating cylinder firing
- 85 ranger 2.8L carb problem
- Truck V6 durring the Inline six???
- Removal of heater hose steel nipple from intake manifold 4L OHV?
- 4.0 SOHC High Idle Fixed...
- 4.0 SOHC Timing Chains
- Engine weights 2.8L and 4.0L v6
- Ford 2.8L to 4.0L swap
- 98 4.0 humming noise
- pushrod 4.0
- Ranger & Explorer 4.0 OHV Compatibility
- fuel filter
- 94 explorer 4.0
- '94 4.0L Tap/Exhaust Leak?
- Coolant sensor help
- Will the 2.6 v6 intake fit on a 2.9L
- Help! Timing is out of control for '89 2.9L BroncoII
- 93 4.0 Power options?
- Piston Slap in 4.0
- 1997 4.0 spark plug wire routing
- 1992 explorer 4.0 OHV Timing
- timing info needed
- 99 4.0L Upper Intake & EGR
- explorer stalling out
- Merkur Exhaust Manifolds
- firing order
- 1990 Ranger 4.0 V6 torque specs
