- 2.9 timing mess
- 2001 ranger motor swap sohc for ohv
- 4.0 rear timing chain access
- 2.9 exhaust manifold bolts
- HELP !!!! Explorer will not start
- 4.0 SOHC Starting Problem
- 2.9 high volume oil pump
- Fuel Pulse Width
- Adding more power
- Truck shutting off?Other flaky things?
- PO174, PO171, AND P1507 problems
- PO171 and PO174 banks 1 and 2 too lean
- how is the ECU grounded?
- cranks but no start
- 86 2.9 no spark
- Plugs and Correct Gap
- slave cylinder 94 ranger 4.0 6cyl
- motor rattling
- question?
- codes without scanner???
- 91 ranger wiring harness????
- 91 Ranger 4.0L
- sequential fuel injection
- 2.9 V6 Ford Ranger Engine trouble
- Fuel pressure regulator replacement
- 96 explorer 4.0
- 2.9 V6 Piston/rod Orientation
- 2.8 swap
- Pushrod 4.0 torque specs?
- 4.0 Engine ID
