- 2.9 fuel injected idle speed adjustment
- 2.9L TFI module, bad for good?
- 4.0 crank in 2.8 or 2.9?
- Need data, Ford 4.0ltr, V6
- Need data, 2.8I, 1981
- 87 BII 4WD Standard.. No spark, help!!
- tps sensor
- tranny issues
- exhaust kit for 2.9????
- '88 Ranger modulator valve location?
- Camshaft position sensor Swap?
- 1990 2.9 ford ranger firing order?
- throttle body spacers
- Battery Drain 1997 Ford Ranger
- 2.9 v6 head bolts
- 2004 4.0 Ranger spark knock Q>>>>?
- More on 1989 ranger with 2.9
- 1989 ranger 2.9 problems
- 2.9L Ford Bronco II 1986
- 1990 Aerostar Firing Order Goof?
- Sven Pruett's book on Ford engines
- 1991 4.0 won't run, gas going into oil???
- valve cover
- 2.8 carb question
- 2.9L Cracked Cylinder Heads
- 2.9 oil sending unit location
- Just a dumb Question
- need help on timing, please
- Poll: 4.0 Sohc Lucky Or Not????
