- Best Bangs for my Buck?
- 96 4.0l v6 hesitation
- shimmy/shake/shudder 4.0 liter
- 89 ranger 2.9 oil leak
- 2.8l valve lash
- 4.0 head gaskets?
- 2.9/4.0 head swap
- 4.0 Lifters
- Compression on a 2.9
- HELP! Starter/Flywheel 2.8L
- SOHC VIN X & VIN E
- bad idle
- Electric water pump
- 2.9 head gasket{WHY THE METAL BETWEEN CYL}
- 2.8 wont crank over
- I bought a 90 ranger with 2.9 what should I know about this 2.9?
- 91 Ranger 4.0 max overbore
- 1987 2.9L Problems
- 87 2.9 valve lash adjustment
- 92 4.0 with a rattle
- 92 4.0 nomial temperature range
- Newbie
- throttle body 4.0 sohc
- 92 EXP Inlet Air Temp Regulator System
- 4.0 ranger tick
- Aftermarket 2.9 cam
- can of worms?
- clutch pedal
- 2.9 Ignition Timing
- 2.9 oil pump priming
