- 5.0L ranger 1987
- 4.0 In Pinto
- 4.0 engine intake manifold
- 4.0 Compression test results...
- Whats the Difference between code E and X 4.0 engines.
- stroke a 2.8?, can it be done?
- 2.9 Mpg
- 4.0L Performance
- 4.0L V6 engine noise
- 4.0 compression?
- 92 4.0 v6
- painting the 4.0 badge
- Adding a passenger airbag question
- 2.9 has a rough idle HELP!!
- How reliable is the OHV 4.0L, and what problems should I know about?
- Just A Question About Solid Lifters
- James Duff Chip
- using 95 4.0 heads on 92 4.0 block
- 88 ranger 2.9 surging and missing when cold
- Head bolts on 92 4.0L
- oil hole on connecting rod
- Taking head off of 92 4.0
- piston clearance
- 86 Bronco II fuel rail removal?
- 93 explorer no power on hills dies
- best method to remove exhaust manifold bolts
- me thinky me have a cracked head
- Major coolant leak
- 89 Bronco 2 2.9
- engine sales recommendation
