- Need more power!
- cam synchronizer tool
- loosing power Ranger 2.9 L V6 Year '88
- '92 Explorer: Where's the SPOUT connector?
- 3.0 trans to 4.0 trans?s
- 96' Aerostar 4.0L cylinder 6 misfire
- 96 Exp 4L V6 PCM #needed-dealer says 600 plus
- 96 Explr 4.0 Fast Idle - IAC, PCM, MAF???
- Ranger 2.9 L Distributor
- What engine do I have????
- 4.0 SOHC Misfire
- a 4.0 SOHC in a 2001 Ranger question
- 2.9L surges and runs rough when warm
- Size Matters
- 2.9 bad injector?
- water in the intake
- 1999 explorer sport 4.0 engine swap to V8???
- Help! Gap Ratio and general performance
- 4.0 no compression on #1 cyl and white smoke
- New Spark Plugs - Recommendations?
- stroking 2.9 with 4.0 crank, mopar 3.3l pistons need info
- Steady miss-fire @ 100,000 mi.
- 91 Ranger 4.0 No start No spark no Inj pulse
- engine block for 94 ranger
- OHV 4.0L starter differences
- What was this?
- 2.9L V6 on BII - Works ok, sounds terrible, won't pass PA emissions
- Vacumm diagram 2.8 ranger carb 2150?
- 4.0 pushrod v6
- Intake Kit problems
