- changing a 2.8 with a 2.3
- ford tempo excessive oil consumption 2.3
- Recommended oil weight?
- Solving a strange knocking from Heater Hoses
- engine swap????
- 2.5L VIN-C 2000 Ranger Spark Plug Replacement?
- 98 RANGER bolt ons
- performance
- 2.3 specs?
- 2.5L vs 2.3L
- how to get codes off of obd2 at home
- where have they hid the temp sending unit
- Any problems replacing a 1991 Ranger 2.3 with a Mustang 1991 2.3L
- Clutch
- 84 Ranger, 2.3L carb swap-smog delete help needed
- Somebody explain the reason for 8 spark plugs in a 2.3L 4 cyl
- did every one stop posting?
- No timing belts
- Would you like a bigger easier to change oil filter on your 4 banger?
- timing belt woes
- coolant drain on a 2.3L block?
- odd engine noise
- F150 Vs. 4 Banger Vtec
- I need horsepower for my 2.3L!!
- 02 Ranger 2.3L Cold Air Intake
- 2.3L hsc topaz 89' stumbling..
- DIS problems
- replacing drum brakes NEED INFO!!
- The long and the short block of it all!
- throttle kicker please help
