- head swap
- Above Casting code
- 89 F-150 Carb, Intake, and cam question please help
- 302? will newer, pan fit
- 86 302 running way rich
- 1 Pc Rear Main vs 2 Pc rear Main
- Galaxy Engine?
- 5.0 weak idle. need help asap
- 351w heads 302 block
- MSD for 5.8?
- 92 Ford F150 - possible blown head gasket
- Harsh shift E4OD
- 260 v8
- what is this
- 302 swap
- rough idle/puffing blue
- Locating the ID tag on 351w
- Should I use this 302 or start fresh?
- 289 backfire
- What Heads Do I Have?
- casting number help
- Which pushrods to use???
- Years for roller lifters on a 5.0?
- miss firing
- 351w year model
- Ford 302 Engine
- 351w smog delete questions
- idle problem
- 84 351 head ?
- Engine Identification Help!!!!!!!!
