- late model 302 heads to early 302 motor
- Will 1970 351W heads work on my 1984?
- oilengine oil pan swap-302 truck,onto a 302 car engine
- Additional parts for replacing valve cover gaskets?
- what motor to use
- 5.8L to 408 whats needed?
- No spark in 302 with brand new HEI
- 1986 F 150 5.0L needs help
- edelbrock or holley double pumper carb?
- Smashed Spark Plugs (351W)
- 331ci stroker kit...
- Rev limitor
- Roller 302 with archaic components?
- is 5w40 ok in 302 that will run in winter.
- swapped 302 to 351, grinding/scaping noise from bellhousing
- really bad need help
- serpentine system
- Is this engine worth the money?
- Hey guys
- Rear main seal leak
- 351W Block Identification
- PCV and Custom Valve Cover
- Rear main leak problem ?
- Engine RPM? 95 F250 5.8L 4.10 Gears
- '91 351w coolant leak at the intake manifold
- Will this work?
- 88 5.8 efi needs help
- 302 bellhousing pattern Q
- 302 Identification
- 302/351w weakness
