- 351 W vs 351 C
- Engine Indecision
- Ditching the six,going to an 8!
- distributor problem ? PLEASE HELP!!!!
- Cylinder head ID
- Stock heads and Roller Rockers
- 1972 351W Pressure Relief Valve
- Stange Sounds from Engine...
- lincoln 5.0-5.0ho project soon
- 302 EFI to Carb
- Pan swap,'78 302
- Heads
- lifter preload help
- code 21 & 24
- Valve Guides
- 302 with aod transmission
- decisions decisions another truck decision
- 351 runs like ****
- 302ci
- 88 351W heads
- compression ratio
- horsepower?
- new motor or rebuild?
- 79 Water Pump Change?
- Rear main seal
- fuel probs
- 1990 351W Initial Timing
- new cam, have questions
- ?351w conversion to hydraulic roller cam
- adjusting efi
