- 351w HO compresion
- Correct oil Pan for my 302
- 89 5.0L efi-Idles high, sometimes lopes, any ideas?
- 351 headers
- 94 F150 5.0 timing set silent or standard?
- 5.0 has starting problems
- 302 won't run
- 351w OLDER VS NEWER
- 289 water pump bolt broke...help!
- horrible oil pressure
- 351w buildup
- truck won't start - help
- ANything and everything
- 351w flywheel
- 351 knocks when warm
- 5.0+EFI problems still - not idleing - bad motor?
- Knocking
- 1987 302 Specs Needed
- 302 years...what will work
- 87 302 FI misfires only when warm.
- Oil Capacity & PCV Valve
- 302 Only Starts With Fluid
- timing on 94 302
- PCM info?
- Oil pressure problem on my 1989 351w
- 91 5.0 Block questions
- Need info on E7TE heads
- Best Spark Plugs?
- Serious '76 302 problems.
- Could I still have carb icing?
