- Its time for EFI
- transmission compatability ????
- Cam or rockers
- big block project down the drain, small block project ideas in the works?!
- 351 has no rpms and misses
- 302 stroker kits?
- 289 problems advice needed...
- 289 head #id
- 1983 351w ignition question
- 302/351W compatible parts questions.
- coolant flow direction question
- Carbed 302 build - cam/intake/carb combo recommendations wanted
- Help building a supercharged 302
- rocker arm shims
- Bearing and Head Gasket Advice
- no spark or fuel problem
- Timing
- Engine Differences
- 351w plug pattern
- Whats 351W D0 heads worth?
- 76 Superduty firing order
- 302 Electronic Distributor Conversion
- Anyone read the diesel power article?
- horsepower ?
- Short headers
- 351w long rod / long arm, anyone done it?
- Engine miss
- 83-84 cast aluminum valve covers
- 302 idling problems
- Ballance weight
