- 86 5.0 high idle problem
- Updating a 351W
- Is This Right????
- machining work
- Head Bolts / A.I.R Ports
- Boss/Cleavor Heads
- Quick Help needed. Valve covers
- Trouble Starting
- How Will this Combo Move My Truck?
- 351W Leaking Antifreeze
- HC's high on 302 any quick fixes?
- Guide plates
- 351 performance rebuild
- Anyone know if SD or MAF will handle 408W?
- will these heads work??
- Swapping a 92 351W into a 85 F-150
- Crower Lifters
- 2 or 4 bbl carb setup?
- Cam and ignition timing?
- swapping out distibutor
- 351 Water Pump
- anyone running the comp cams 31-255-5?
- Easy way to ID a 302
- 351w
- High speed spit, pop, missfire, and hesitating?
- Code 542
- 351W upgrade to EFI
- 84 351W wont run
- Well...what do I do now!
- valve cover removal
