- 1988 Ford F-150 keeps stalling out
- Piston to valve clearance question...
- 4* Advance question on 302HO cam.
- 351W Oil Pump Shaft - which way is up?
- 289 eng balance internal or external
- Quick!!!!
- need some advice
- Playin' With Desktop Dyno
- Valve Spring pressure
- 79 302 started loping more and suddleny feels more powerfull
- 351 build up: need imput!
- TFI-IV ignition system ?
- manifold and heater hose coolant leaks
- 302 "ticking"
- Should I rering it or not
- holley 4 barrel wants to die when i mash it
- 351w with 400m parts
- 1991 351W compression
- 32 Valve 5.0 302 Myth or Reality
- 1995 F350 w/5.8L
- 302-351
- 351W Issues, I need your help!
- 1977 302 compression amount?
- Getting the Most out of a 5.0
- what is this part and do I need it?
- Map Vacuum line
- 351
- coolant leak on 351, need help
- adusting timing in a 302 with a cam
- How to adjust valves on 289
