- Starting 351W Build, Need Input
- Stock '93 F-150 5.0 Cam Specs?
- build ideas
- Mechanical Fuel Pump choices
- first time with EFI
- When did 5.0L switch to roller?
- please answer
- BOSS 302 Water Pump Pulley on eBay
- 302 id????
- 302 Towing
- 351W intake manifold help needed
- Initial timing tdc compression or exhuast stroke?
- 1974 302 ceased
- 1972 351W build questions
- EFI cam upgrade in a MAF truck?
- Need Guidance and Help identifying a motor
- Can you diagnose my 398W with a video?
- Bigger cam in a EFI 5.0L ?
- stock 302, ideas???
- Ford 5.8 Power
- 5.0 sensors/senders locations
- efi intake question
- 91 302 f-150 4x4 stalls
- 289-302 cylinder head casting numbers
- 1991 302 running rough, really low power
- 302 Compression ratio troubles
- front main leak 88 351W
- arggghhhhh!
- Race/Street or RV/HeavyDuty
- HP and TQ guess?
