- Bolt pattern on a 351C
- Badger Flat Tops and CR Quesitons
- Flywheel question
- 351 M cylinder bore
- 351c aluminum heads
- Question on intakes
- Replacing crank or rebuild engine?
- predetonation trouble!!!!
- Gear drive for 400 anybody?
- Help with total emissions removal PLEASE!
- 1970 to 1987 351 swap
- Vaccum Diagrams
- vacuum advance
- 351m smog crap
- casting #'s on a $20 "351c"??
- 400 Rotating torque- FYI
- Dashpot/Solenoid?
- What did I do wrong!
- crank pulley
- head swap/spacer q's again
- Egr Or Not?
- set timing
- Badger Quality Control Questions
- 351M casting number
- 77 F150 4x4 overheats
- roller rockers?
- 351m
- flat top pistons stock?
- Puff Of White Smoke??
- High idle
