- 351M bogging under load
- Almost there, additional items to run a hv oil pump
- 351M cranks, all drilled for manual tranny?
- spiting gas/oil
- 351c pistons and 351m-400
- Dish depth in stock 400 pistons
- 400 upgrade advice needed
- TMI 434 Intitial Results
- 434- Update
- holy grail found; factory 400 4V intake/carb
- question about timing chain....
- 351M oilpan on 351C
- exhaust gasket and frustration
- installing headers on a 400
- 1971 351c 4v
- Trouble Identifying an engine
- Need help again.
- Can I make a 351m to a true 400
- What needs to be done to the heads?
- Duraspark Adjustable Vacuum Advance
- firing order
- 434 Video
- Dead 400?
- 400 crankshaft questions
- cam for a 400
- Water leak on '78 400 left head
- Oil Pump Pickup
- CAL cams camshaft
- EGR valve on 400
- Swapping cams
