- E85
- oil pressure port
- Scorched oil
- Valve Covers
- Dyno (desktop #'s) in and wow????
- Cleveland
- New Oil Pump, Still Low Pressure
- 351m electrical problem?
- Timing cover :Is it the only way?
- Oil leak on a 400
- Dual Exhaust 351M to 400 in F250 super cab
- Having trouble idling/timing 351M
- Muddin in the LTD
- Oil pan remove, F-350 400 engine, 2 wheel drive
- Fire from manifolds.
- Not sure what Cleveland I have
- Dizzy Shaft Grinding
- Water pump leaking
- 351m misses and to hot
- Headers for 400??
- Rear main seal
- 600 cfm too small?
- Firing order 351m
- Mass Flo EFI
- Straight up timing
- Carlisle All Ford Nationals
- 351M Issues / NEED HELP
- kb oz...build update and specs- need #'s run
- 351M carb
- Valve difficulties...
