- my 351m keeps hesitating
- 400 Intake Gasket Leaks
- Correct Dipstick?
- What can i do to a cleveland faster then a hemi?
- ford cylinder head numbers
- started pulling apart the 400 and....
- Comp cams retro roller kit and dizzy gear
- How many cubes?
- Detonation & Timing
- Same ol' "HOW MUCH HP" Question...
- Trying my best to keep people well informed
- Harmonic balancer bolt
- valve cover question
- Variable oil pressure
- Can a 351-400 make "That Much HP" ??
- Weiand #8310 intake manifold
- Replacing rear main seal
- Build Plan: Too Much Cam?
- 400 build compression, cam, piston selection
- Easy mods for HP gain
- Need Engine Asap!!!!!!
- WWWHHYYYY the poor mileage on propane
- my 400 isn't working right
- Zollner pistons?
- Engine Swap, Wild for Mild(er)
- Strange noise from crankcase and puffs of smoke
- 351C vs 302
- 400 cylinder wall thickness
- pro comp (chi copy) heads
- Camshaft ID
