- dropping oil pressure
- 351M mated with a C4?
- Info on 400M - History
- replacing rod/main bearings/front seal/rear main, any help/suggestions welcome
- 400 Cam Advice
- 351M vacuum hose
- 71 distributor Recurve or not?
- 351 Clevo Vacum Hoses
- 400 heads don't want to come off
- 351 to a 400 on a small budget
- more pics...
- 400 vacuum ALL messed up, need diagram/routing help please! DETONATION!!!
- Looking for a mechanical fuel pump
- Straight up timing?
- Cam Help for 400
- valve train geometry and no bent push rods
- oz head 57cc
- pic of my 400 w cleveland heads
- Small or Big Block
- Quick help needed, can you identify a 351M and 400 externally?
- '72 4v (cj) heads
- Engine swap
- Vacuum Gauge Hookup
- CHI 2V head flow numbers for my 434
- Hot Rod 400 build up.
- timing chain 351M
- how do you add a picture
- 400 pulleys
- Erson ever make a 400 cam?
- 400 made of wood, not p-ayr
