- size of oil pan drain screw ?
- Engine starting problems
- Pushrods and Lifter Installation Info needed, ASAP.
- heders help
- holley carb on a 400
- 351 c pistons to 400
- Bad Oil Preasure
- which timing chain do I have (pic inside)---where do I get a "straight up chain??"
- 255deh or xe256
- Overhauled 400-Upgrades?
- Building 351M
- Bad Gaskets
- oil pan questions
- Oil pressure dissappeared
- belt conversion
- 1977 eng for grabs.
- exhaust valve porting
- adjustable valve train
- Knocking sound only in park or neutral
- Temp sensor location 400
- Macungie PA
- A few 351M block questions.
- 351C Build
- Building a 400 need help.
- chi heads
- Which Carb?
- best distributor?
- Intake Install
- Head gasket leak?
- carb tuning
