- Valve Seals: Whaich Ones Do I use?
- 351M....400 crank
- 351C year
- delete
- engine advise? rebuild or buy new
- input on carb spacer
- Off Topic - Ford PS Pump
- got the new 400 assembled for the bronco, then bought another truck....
- New engine wont start
- water in oil head gasket thread to summarize
- 400 harmonic balancer
- Stroking With Chrysler Rods
- Heads won't come off
- engine masters simplified
- 351/400M Stroker Build
- preformer 400 problem
- Bent Pushrod. How Far Should I Go Now?
- fuel pump
- Which Timing Notch?
- What does a 351/400M weigh ?
- Heater hose fitting in Block....Snapped....IDEAS!!!
- 400 Project
- A couple questions on valve train set-up on 351M/400.
- Need torque specs for 351M/400 engine, if possible...
- Is anyone familiar with this intake? Edelbrock and says 400 on it...
- Can you remove water pump with the fan attached?
- What type of cam is in a 351M/400: Flat Tappet, Hydraulic Roller?
- Engine is Stuck
- 400 or 351m
- hot to trot
