- one piece oil pan gasket?
- Double Check Bolt Torque. A Little Incentive.
- Questions about 4bbl closed chamber heads on 400
- 400 distributor?
- Stock cylinder heads welding
- Napa thermostat
- more drama
- Power adders for stock 1979 400
- Straight up question.
- Cheap Rebuild on a 400???
- Just curious..
- Exhaust valve interchangeable?
- 351 Cleveland Oil Light
- can't seem to get my 400 tuned correctly
- New Roller Rocker Arms and camshaft
- smoke on start up
- 1971 351 #'s help please
- flex plate, car vs. truck?
- Motor has "no balls"
- rebuilt or not?
- Anyone try a MSD adjustable timing
- Serial on intake
- What should I buy next for my 400? (really need your help)
- installation- sealing cooling system
- How much horsepower is the 351M/400 block capable of?
- Best intake that matches 351M heads?
- 351M/400 stock deck height and pushrod size?
- How much did you spend on your 351M to 400 rebuild?
- Stock 400 head polish
- 351 4v cj- '72 tech question- for builders
