- 79 f-150 w/400 smoking
- What a deal! Question about bore size also.
- got some oil burning on the head
- Tming chain slack measured at distributor?
- New motor no vacuum
- 400 stock cylinder head, valve boss maybe ?
- carb backfires at RPM
- DCR opinions please
- hesitation help
- Hey guy's! Quick intake question!
- bearings
- 400 with Dis question
- Which Cleveland?
- Backfiring
- 351m Cylinder wall/Block Valve reliefs
- Powerheads.com porting
- Roller rocker arm sale- limited supply
- waterneck restrictor for a 400??
- Valve cover gaskets
- 400m deck height?
- *quick oil pan question*
- straight exhaust,no mufflers
- E85
- 351C torque specs
- Knock when starting
- one piece oil pan gasket?
- Double Check Bolt Torque. A Little Incentive.
- Questions about 4bbl closed chamber heads on 400
- 400 distributor?
- Stock cylinder heads welding
