- horsepower, hot rod?
- eccentric cam for mechanical fuel pump.
- 351m400 horsepower
- 400 Engine Compression
- Carter Carb with off idle stumble
- Oh No!! White gunk in the breather!
- K&N air cleaners
- vibration at RPM
- EBay Warning
- rear main ?
- stuck distributor
- 400 timing problem
- 1977 400
- Vacuum 1977 400
- no oil to the valves
- No oil to valves
- what should ported vacuum read at carb?
- rebuilding 351m as a 400
- What Can I Replace My 351m With?
- Over heated
- engine troubles?
- Cobra Jet Cam?
- 351m oil pressure problem
- Block Hugger Headers???
- Ford Big BLocks
- 351M Oil Pressure low in Drive
- Dyno 2000 Simulation
- Off Topic: No replies please- 427 V10
- Moroso oil restrictor kits for 400
- timing on a 351c
